Автор: Denchik (---.mosgortrans.com)
Дата: 21-04-10 16:03
New Standard TT2A - TINY TACH™
RPM reading adjustable from 1 spark per 2 revolutions to 8 sparks per revolution. One TINY-TACH™ now works for most gas engines.
RPM display from 1 to 19,000.
RPM update time 1/2 second.
Hour meter records total actual running time on your engine.
Job timer can be reset to record run time for record keeping.
Coax cable transmits signal without EMF interference.
1 Antenna cable winds around your spark plug wire to give you the RPM reading – clean and simple to attach. Signal strength can be controlled by the antenna wire.
Standard cable length is 6 feet. Additional length can be added at the factory for $10. If not standard, please specify total length needed in the "comments" section at the end of the order page.
TINY-TACH™ unit is potted to prevent damage from moisture and vibration. Lithium battery life 5+ years, not replaceable.
